Activity Forums Adobe After Effects Rotobrush dynamic link frustration after effects / premier cc
  • Rotobrush dynamic link frustration after effects / premier cc
    Posted by Joe Gubb on November 4, 2013 at 8:57 am
    Hi guys,
    I am working on a music video at the moment but I am having real problems with roto brush I have cut a person out in my after effects dynamically linked comp. the first draft when fine and it updated into premier but when I went back to Make adjustments to the roto it didn’t update, others effects and layers in the same comp have updated into premier it’s just the roto that hasn’t. Any idea?
    Joe Gubb replied 12 years, 10 months ago 3 Members · 3 Replies
  • Michael Winters
    November 5, 2013 at 5:39 am
    I’m having the exact same problem. When I use Rotobrush the effects don’t come through to Premiere but every other effect carries through as expected. I’m using CS5.5
  • James Osbun
    November 5, 2013 at 5:44 am
    Ive not used this function before as I typically avoid DLs, but is there any button/overlay-method that condenses all your roto? It may simply be that AE wasn’t coded well in this area and isn’t capable of putting everything together….? I’ve not had much stability with DLs, so this doesn’t surprise me. Anyway, just a thought.
  • Joe Gubb
    November 5, 2013 at 9:40 am
    Ok guys! We’ve solved it!
    When we were roto brushing we had dropped the resolution to a third as we were working with 4k but that ment when it was being pushed back to premier and yeah Rez was changing back to full the roto would have to do a run through again and this is where it messes up so if you do everything in full red whilst you are roto brushing it should come through to premier
    Joe Gubb
    Dop am Freelance filmmaker
    Joegubb.co.uk
    Joegubbfilm@gmail.com
