Activity Forums Adobe After Effects RotoBrush Bug?
  • RotoBrush Bug?
    Posted by Lee Kessler on July 26, 2011 at 7:49 pm
    Hey Everyeone, I am a veteran AE user and was experimenting with the new Rotobrush tool. I usually do frame by frame rotoscoping but wanted to give this a shot.
    I am having an issue where I paint an area to ADD to the selection but the pink outline will not move. It seems like the area I paint is only effected in the next frame. also the “Span keyframe” (not sure what to call them, I am referring to the keyframes within a “span” area) are not masked. the frame before and after are masked, but the actual frame that the “span keyframe” is on, does not contain a mask.
    If I am not clear please let me know, i will try to expand further.
    Hinny Tran replied 13 years, 7 months ago 3 Members · 3 Replies
  • Todd Kopriva
    July 27, 2011 at 12:46 am
    You really need to watch the tutorials and read the documentation first. Trying to use the Roto Brush tool without doing so is certain to cause frustration and confusion.
    https://blogs.adobe.com/toddkopriva/2010/04/roto-brush-in-after-effects-cs.html
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Lee Kessler
    July 27, 2011 at 3:33 am
    i have read it, and im VERY comfortable with after effects so using the roto tool is kind of second nature. The problem i am describing is a little deeper than that thin “documentation”
  • Hinny Tran
    February 1, 2013 at 6:40 am
    Yes My pink outline has stopped moving as well. It was working fine last night and now it’s not. Let me know if you find a solution to this. Cheers!
