Activity Forums Adobe After Effects Roto Brush mismatch AE 5.5 REDUX
  • Roto Brush mismatch AE 5.5 REDUX
    Posted by Bruce Tovsky on April 9, 2013 at 6:25 pm
    hi all
    i recently had the need to use the Roto Brush on a job, something i rarely use, and ran into a slight issue which though it didn’t stop me caused me worry. searching the forums for this error about a “frame mismatch” between clip and comp i found many replies regarding interlaced footage and comp fps – 29.97 vs 59.94 etc. however, i have 23.976 progressive footage, and AE is asking me to create a 47.96fps comp.
    thoughts? when i dismiss the error it seems to render fine, at least it renders a RAM preview fine…
    cheers
    bruce
    Bruce Tovsky replied 13 years, 5 months ago 2 Members · 5 Replies
  • Todd Kopriva
    April 9, 2013 at 9:45 pm
    If you are using interlaced footage, you have different information on each field. To make use of this, you need to use a composition set to a frame rate equal to the _field_ rate of your footage. If you don’t, you’re throwing away half of the information that Roto Brush has to work with.
    This is true not just for Roto Brush, but for any workflow involving drawing or tracing on each field, such as conventional rotoscoping with masks.
    After Effects team blog
  • Bruce Tovsky
    April 9, 2013 at 9:53 pm
    hi todd
    thanks for the reply, but as i said in my post, i have progressive footage. i know all about interlacing, etc and it’s affect on the roto tool, and back in the “good old days” of video when i actually used interlaced footage (been awhile) i had to separate footage and deinterlace and all of those messy things. i love the RotoBrush, and wish i knew why it wanted me to work at 47.86fps….
    cheers
    b
  • Todd Kopriva
    April 9, 2013 at 10:11 pm
    It thinks that your footage is interlaced.
  • Bruce Tovsky
    April 10, 2013 at 1:40 pm
    hi todd
    hmmm. source is an avid project, 1080p 23.976, exported as animation codec. i just checked the settings and “Deinterlace Source Video” is NOT checked, so that may be the culprit. since it wasn’t interlaced i wouldn’t expect that i needed to check that but will test.
    thanks
    bruce
  • Bruce Tovsky
    April 10, 2013 at 3:17 pm
    ok, did another export WITH deinterlace checked, replaced the previous footage with this new clip, and when i went to the first Roto’d clip in the timeline i got the Roto mismatch error again, but this time reversed: instead of the error saying my 23.976 clip needed to be 47.95 it said my 47.95 clip needed to be 23.976. however, this time it did not clear my roto info on the clip and seems to be rendering fine (fingers crossed.)
    b
