Activity Forums Adobe After Effects ROTO BRUSH Distortion Bug
  • ROTO BRUSH Distortion Bug
    Posted by Paul Whishaw on July 13, 2011 at 8:22 pm
    I have used the Roto Brush tool on a particular scene and for the most part it is excellent. There is one frame however that is messed up and I cannot seem to find the cause. There is a section of the frame that I am working with that gets mirrored and smear across the frame. I’m including a link but can’t show the whole frame for copyright reasons.
    https://i263.photobucket.com/albums/ii140/Bentleysuper8/Screenshot2011-07-13at121820PM.png
    Hopefully you can get enough info from the shot to see what is happening. Anyone see anything like this before?
    Rob Neal replied 15 years ago 3 Members · 3 Replies
  • Declan Smith
    July 13, 2011 at 10:04 pm
    I had the same problem and found that for me, it seemed to relate to interlaced footage / rendering out to interlaced. I changed renders to be non interlaced and if seems to have fixed it for me.
    Declan Smith
    https://www.madpanic.tv
    FCS3 / After Effects CS5 / Combustion / Canon 7D / Canon XL2
  • Paul Whishaw
    July 13, 2011 at 11:28 pm
    I don’t think interlacing could be the problem as I’m working with Pro Res footage. This happens right in the composition as well, before I export anything.
    It has something to do with the Decontaminate Edge setting. While on I get the smeared mirror and when off it is clean (but edges look bad).
    Paul Whishaw
    PDVpro.com
    “If it moves, We’ll Shoot it”
  • Rob Neal
    July 28, 2011 at 9:11 am
    I agree. I am using TIFF plates and getting the same problem. Fiddling with the decontamination settings can sometimes help.
    http://www.robneal.co.uk
