Activity Forums Adobe After Effects Expressions Rotation with Opacity
  • Rotation with Opacity
    Posted by Melissa Franch on April 20, 2023 at 6:33 am
    Good morning,
    I want to make a layer have opacity 0 or 100 depending on the rotation of another layer. It is like a cover that is behind a spinning object.
    I have solved it like this:
    var rotationAvatar = thisComp.layer(“Control General Avatar”).transform.yRotation;
    if (rotationAvatar > 52 && rotationAvatar < 310) {
    100;
    } else if (rotationAvatar > 52 + 360 && rotationAvatar < 310 + 360){
    100;
    } else if (rotationAvatar > 52 + 720 && rotationAvatar < 310 + 720){
    100;
    } else if (rotationAvatar > 52 + 1080 && rotationAvatar < 310 + 1080){
    100;
    } else {
    0;
    But this way I only have 3 laps solved.
    I think I would have to do a for, but I am not able to solve it.
    I would also like to have the possibility that the opacity does not jump from 0 to 100 at once but does a little interpolation.
    Any ideas?
    Brie Clayton replied 3 years, 5 months ago 3 Members · 3 Replies
  • Dan Ebberts
    April 20, 2023 at 4:55 pm
    Play around with this:
    var rotationAvatar = thisComp.layer("Control General Avatar").transform.yRotation%360;
    if (rotationAvatar < 181)
    ease(rotationAvatar,52,82,0,100)
    else
    ease(rotationAvatar,280,310,100,0)
  • Melissa Franch
    April 25, 2023 at 7:51 am
    You are magic! Thanks!
  • Brie Clayton
    April 25, 2023 at 3:03 pm
    Thank you again, Dan!
