Activity Forums Adobe After Effects Expressions Rotation speed linked to motion return to zero
  • Rotation speed linked to motion return to zero
    Posted by Jason Jantzen on August 6, 2015 at 12:25 am
    I found this old expression from JJ Gifford’s website.
    Basically what I’d like to do is modify it so that my circles return to 0 when they’ve finished animating instead of ending up rotated all wonky. The circles are animating in the X position from point A to point B, then back again. Any thoughts?
    circumference=width*( scale[0]/100)*Math.PI;
    distance=position[0];
    (distance/circumference)*360
    Jason Jantzen
    vimeo.com/jasonj
    Jason Jantzen replied 11 years, 1 month ago 3 Members · 5 Replies
  • Jürgen Hackl
    August 6, 2015 at 9:30 am
    Try this one:
    rot = (distance/circumference)*360
    while (rot>360) {
    rot -=360;
    [rot]
    http://www.jxrgen.at
    SXPER RENDER – After Effects Render Script
    http://www.jxrgen.at/sxper-render-after-effects-script/
  • Jürgen Hackl
    August 6, 2015 at 9:37 am
    simpler:
    (distance/circumference)*360 % 360
  • Jason Jantzen
    August 6, 2015 at 7:40 pm
    Thanks for taking a crack at it! But it still ends up settling in a wonky rotation angle.
    Jason Jantzen
    vimeo.com/jasonj
  • Dan Ebberts
    August 6, 2015 at 9:35 pm
    You might just need a reference position. Try changing you second line to this:
    distance=position[0] – position.valueAtTime(inPoint)[0];
    Dan
  • Jason Jantzen
    August 11, 2015 at 3:19 pm
    Thanks Dan, but that gets the circle to start at 0 degrees and then roll forward the appropriate amount. What I’m trying to do is get the circle to end on 0 degrees. That way I can inflect any amount of bounce back using just the position and not worry about getting the rotation right.
    Jason Jantzen
    vimeo.com/jasonj
