Activity Forums Adobe Illustrator Rotation point in Illustrator
  • Rotation point in Illustrator
    Posted by Alex Kuzelicki on January 28, 2009 at 11:34 pm
    Hi there,
    This may be a super-basic question but I haven’t been able to find the answer yet.
    Just want to know if and how you can move the rotation point of an object/illustration in Illustrator?
    Basically, I just want to shift it from the middle to a corner (the same way I can shift the Anchor point in After Effects) so I can rotate the object around that corner.
    Sorry if this is a no-brainer. Thanks in advance,
    ALEX
    Alex Kuzelicki replied 17 years, 6 months ago 2 Members · 2 Replies
  • Vincent Rosati
    February 23, 2009 at 9:54 pm
    You can’t permanently change the center point. The best you can do is to use the Rotate Tool (R) to move a center point for rotation, but after the you’re done with the tool the object will hold it’s original center.
    Here’s something about using the rotate tool…
    https://library.creativecow.net/tutorials/adobeillustrator#rosati_vincent
    You could also group your object with a large empty square. Where you would position the main object’s desired center-point to the center of the enclosing square…
    Of course, you would not use the dotted line in your version. The stroke would be empty.
    Vince
  • Alex Kuzelicki
    February 25, 2009 at 3:44 pm
    Hey Vince,
    Thanks for the advice and leads.
    Appreciated,
    ALEX
