Activity Forums Maxon Cinema 4D ROTATION Back up….
  • ROTATION Back up….
    Posted by Glenn Takakjian on May 16, 2006 at 11:29 pm
    Is there a formula to avoid the wierd “reversing” effect of a quickly rotating object. Often when you start rotating an object from a stand still, it reaches a certain speed then “appears’ to reverse direction, then reverses again… sometimes again.
    I assume it has something to do with a multiple of the frame rate.
    Motion blur doesn’t help much
    TAK
    Glenn Takakjian replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
