Activity › Forums › Adobe After Effects › ROTATING TEXT AROUND GLOBE
  • ROTATING TEXT AROUND GLOBE
    Posted by Amaliko Carroll on July 24, 2007 at 1:46 pm
    HOW DO I GET TEXT TO LOOK LIKE ITS ROTATING AROUND A GLOBE. I TRIED THE CC SPHERE FILTER HOWEVER, THE TEXT DOES NOT LOOK LIKE ITS COMING FROM BEHIND THE GLOBE.
    THANKS
    Mike Clasby replied 19 years, 2 months ago 4 Members · 3 Replies
  • Mike Procunier
    July 24, 2007 at 1:48 pm
    Use CC Cylinder. You’ll need to have 2 layers of your text… One for thpart in front of the Globe, one for the part behind the globe. CC Cylinder allows you to just render the Inside or Outside of the effect. You’ll see what I mean when you start playing with the effect.
  • Jeff Mcbride
    July 24, 2007 at 2:10 pm
    I would put the text in a pre-comp that is the exact same size as the layer used for the globe (including aspect ratio) Then apply the same filter to the comped layer and it should match up.
  • Mike Clasby
    July 24, 2007 at 6:06 pm
    Not applicable here, but if you trying to do this in AE’s 3D space, I like this:
    https://www.aenhancers.com/viewtopic.php?t=160&highlight=sphere
    Just download the project and swap your text, one letter on each layer, and delete the layers that aren’t around the circumference. The expressions make expanding the sphere relatively easy.
