Activity › Forums › Zaxwerks › rotating text around a circle
  • rotating text around a circle
    Posted by Juan Obregon on November 7, 2007 at 1:04 am
    Hi
    I am using ProAnimator as a plugin in after effects. I need to animate the worth earth
    It needs to come in straight from the left
    and as it gets to the right start to turn (bend)
    as if rotating around the earth
    I have the animation where the word comes from the left no problem
    when it gets to the right it starts to bend but it bends from both sides or the center (how ever you want to see it)
    and the animation first bends the text and then it starts to rotate
    I need it to bend only from the right and start its rotation
    and after it finished doing its 360
    to “unbend” from the left
    Hope you understand
    Thank for any help
    Juan
    Juan Obregon replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
