Rotating Pendulum.
Hi there,
I’ve been trying to make a rotating pendulum (see file for example) but I can’t seem to get it the way I want. I started out with a cube and a sphere: the point is to connect the cube which is up higher to the sphere hand have it rotate while lowering just a little bit.
The way I did it was constraining the spline to the cube and sphere and then aligning the sphere to a helix & animating the position. The problem is I want it to look more realistic: rotate the sphere in the right direction + the spline has a deviation I can’t get rid of.
Please check out my file. I’d love to get some help with this! 🙂
9485_help.c4d.zipHave a great day
