Activity Forums VEGAS Pro Rotating on a path
  • Rotating on a path
    Posted by Anna Prado on March 22, 2011 at 10:38 pm
    I’m trying to make an object follow a straight path, and spin on an axis while doing so. Like a wheel going across the screen.
    What is the best way to approach this?
    I can make it go in a straight line easily using event pan/crop, but making it rotate while doing so is tricky with that.
    Anna Prado replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jeff Schroeder
    March 22, 2011 at 11:10 pm
    Anna,
    In event pan/crop put you cursor near the circle and drag. It will rotate. You can set the rotation center and even key it in manually on the left.
    Jeff
    http://www.narrowroadmedia.com
  • Anna Prado
    March 23, 2011 at 12:40 am
    Great! I figured it out- I wasn’t setting the rotation center properly.
    Thanks for helping!
