Activity Forums Adobe After Effects Rotating noise to not face the camera
  • Rotating noise to not face the camera
    Posted by Joe Myles on March 4, 2015 at 5:26 pm
    Is it possible to rotate a solid with noise applied (turbulent, for example) so that the noise itself respects any rotation away from the camera that the solid has?
    I’ve tried every combination of collapsing, pre-comp and 3d I can think of to no avail. For example, if I apply turbulent noise to a solid, pre-comp it and collapse the pre-comp with the contained solid set to 3d, it doesn’t work. The pre-comp rotates as expected and the noise stays within the boundaries of the rotated pre-comp. In fact, it actually looks like it’s doing everything perfectly until I look closer and see that the grid of noise is still following a perfectly horizontal and vertical grid rather than seeing the small noise squares at an angle.
    Any ideas appreciated.
    Joe Myles replied 11 years, 6 months ago 2 Members · 2 Replies
  • Walter Soyka
    March 4, 2015 at 9:42 pm
    Joe, can you post a screenshot?
    Effects are rendered before transforms, so even a noise effect applied to a 3D solid should show perspective and rotation.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Joe Myles
    March 5, 2015 at 12:00 am
    Well this is embarassing. When I try and recreate the scene it works fine for the first time. I don’t get it, I’m pretty familiar with the quirks of After Effects. Either I was crazy or discovered a bug that occasionally appears. Incase anyone comes across this from a websearch, this is After Effects CC 2014. The version that worked (though I had tried this several times before) was a 3d solid pre-comped into a composition that was collapsed.
    Walter, I sincerely appreciate you stepping in to assist. Much appreciated.
