Activity › Forums › Maxon Cinema 4D › rotating issue in C4D
  • rotating issue in C4D
    Posted by Dwayne Mills on August 3, 2011 at 8:30 pm
    I need help with rotating all three parts of this logo i made at the same time. When i try to rotate them together and keyframe, the objects don’t do exactly what i though they should. All i want is to rotate the whole logo upwards -90 degrees while staying together to reveal the logo upright after the they spin and fall into position like in the first pic. Any help would be appreciated.
    Bill Kelly replied 15 years, 2 months ago 2 Members · 1 Reply
  • Bill Kelly
    August 4, 2011 at 3:29 am
    There’s a couple ways you could do this:
    1.Select all three objects at the same time, right click, go down and select “Group Objects”. This will put all 3 objects into a null object. Then, keyframe and rotate the null object.
    2.Select all three objects at the same time, hit the “C” key to make them editable. With all 3 still selected, right click, go down and select “Connect and Delete”. This will connect the meshes of your three objects into one and delete the original three. Then, keyframe and rotate the one object.
