Activity Forums VEGAS Pro Rotating frames.
  • Rotating frames.
    Posted by Idmmag on March 14, 2007 at 12:55 am
    I’m very new to this program, please bear with me.
    I have a video that has some vertical and horizontal camera movement, which makes the event fit into the lens frame nicely. However, because the camera is turned during filming, the event appears to be sideways at times. So, I was hoping I could rotate these sideways frames in order to get everything to appear rightside up again. When I tried the Tools-Video-Video Event/Pan Crop, I can rotate the clip that I’m on, but don’t seem to have control over each individual frame. Is there a way to rotate just the frames that I need to?
    Hope I’m making sense…
    Edward Troxel replied 19 years, 5 months ago 2 Members · 1 Reply
  • Edward Troxel
    March 14, 2007 at 2:12 pm
    You could use keyframes to adjust the Pan/Crop over time. You could also split the event whenever it needed changing and set the Pan/Crop individually for each section.
    Edward Troxel
    JETDV Scripts
