Activity Forums Adobe After Effects Rotating around a common origin
  • Rotating around a common origin
    Posted by Piotr Raczko on November 29, 2012 at 12:55 pm
    I want to rotate 2 elements, a shape and a text around one common origin and by default it does something else. I select both elements and it rotates around different origins, so after the rotation the elements don’t line up anymore. Do I have to group elements or what do I have to do to rotate 2 elements around the same origin? I’m working in AE CS3.
    Thanks very much.
    John Cuevas replied 13 years, 9 months ago 2 Members · 3 Replies
  • John Cuevas
    November 29, 2012 at 1:13 pm
    Go to Layer > New > Null Object and move that object to where you want the layers to rotate around(this will be the anchor point for both your text and shape layer now). Now parent both layers to the null object. Finally rotate the null object and both layers should rotate in the way you want.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Piotr Raczko
    November 29, 2012 at 1:27 pm
    Awesome, very tricky 😉 Thanks!
  • John Cuevas
    November 29, 2012 at 4:16 pm
    Glad I could help.
    Thinkck.com
