Activity Forums Adobe After Effects Expressions rotating and collating animation
  • rotating and collating animation
    Posted by Rudy Manning on July 8, 2009 at 8:33 pm
    I’m trying to have these icons rotating on a center axis while keeping it’s original Y-Axis stay the same. Also I”m trying to get the icons to scale up as the come to a stop. I’ve tried a couple different things but it’s getting hairy and I have more icons to add.
    Here is a movie sample and a png for reference. Can someone help?
    https://www.pastillastudio.com/pastilla/sample/
    Dan Ebberts replied 17 years ago 2 Members · 3 Replies
  • Dan Ebberts
    July 9, 2009 at 12:40 am
    I think I’d parent the icons to nulls located at the center of rotation. Then give each icon this counter-rotation expression:
    -parent.transform.rotation
    and something like this for scale:
    minSpeed = 0;
    maxSpeed = 700;
    minScale = [50,50];
    maxScale = [125,125];
    s = parent.transform.rotation.speed;
    linear(s,minSpeed,maxSpeed,maxScale,minScale)
    Dan
  • Rudy Manning
    July 9, 2009 at 12:57 am
    thank you so much! One more quick question. The rotation works perfectly. I just need
    to figure out the scale part now.
    I put this on my icon on the scale property/
  • Dan Ebberts
    July 9, 2009 at 5:27 am
    Yes, but you probably need to adjust the four values at the top to get it to work with your setup.
    DAn
