Activity › Forums › Apple Final Cut Pro Legacy › Rotating a lot of clips at once
  • Rotating a lot of clips at once
    Posted by Mrsclean on November 9, 2007 at 4:54 pm
    I am filming with a 35mm adapter, and bringing the footage into Final Cut. The images from the adapter are upside down, and I was wondering if there is an easy way to flip them all at the same time. I feel like this should be such an easy thing, but my brain is not providing the path. Any ideas?
    thanks
    Ben Scott replied 18 years, 10 months ago 4 Members · 3 Replies
  • Craig Anderson
    November 9, 2007 at 5:40 pm
    I think this should work…
    Select all your clips and put them into a timeline. Select one and apply the Flop filter under perspective. Change the setting to Both. Select all the other clips and paste the attributes of the first clip. Drag them back into their own bin called Inverted in the browser, and the filters should follow.
    Cheers!
    Craig
  • David Roth weiss
    November 9, 2007 at 5:51 pm
    Flip one. Then, right click on that one, choose copy, now highlight all the other clips, right click, choose paste attributes, and check the “basic motion box,” and hit okay.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Ben Scott
    November 10, 2007 at 12:21 am
    other way is to create a motion favourite if you are working across timeline
    then select all, make the motion favourite a default filter and then apply default transition
