Activity Forums Adobe After Effects Rotating a gear thats abnormal. Looking for a simple technique.
  • Rotating a gear thats abnormal. Looking for a simple technique.
    Posted by Mark Pfeffer on November 23, 2014 at 11:15 pm
    I’m needing to rotate a gear with pads (not a circle). Trying to figure out the best solution of execution. Any ideas?
    See image below.
    Brian Charles replied 11 years, 10 months ago 4 Members · 5 Replies
  • Mark Pfeffer
    November 24, 2014 at 1:52 am
    It just needs to rotate. Those bumps need to run along the path of the shape.
  • Kevin Camp
    November 24, 2014 at 3:05 am
    You might see if you can manipulate the Vegas effect. It seems like it would get you close…
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Joseph W. bourke
    November 24, 2014 at 3:51 am
    Another method would be to just animate text along a path. Make your path the stroked shape of the base shape without the “gear” nubs, then choose a typeface which has a squared shaped period character, and stretch that character to the height you need. Then animate the text around the path.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Mark Pfeffer
    November 24, 2014 at 5:37 am
    All great options.
    Figured out another solution. Ended up just making that shape and using the dash attribute on the stroke. To animate movement, I just keyed up the offset feature within.
    Back in business. Thanks for all your suggestions.
  • Brian Charles
    November 24, 2014 at 6:34 am
    Shape layers?
    oops too late…
    8217_shapes.aep.zip
    Conveyor Belt
