Activity Forums Maxon Cinema 4D rotate world axis while keeping the same animation
  • rotate world axis while keeping the same animation
    Posted by Tim Simmons on March 26, 2017 at 10:55 am
    I have an object with some animations applied to it. I just noticed that the coordinate space in which the object moves is wrong.
    This image shows what I mean:
    PROBLEM IMAGE
    Is there an easy way to keep the same animation, but switch the axis 180 degrees, so that the z is pointing to me, and y is pointing up? If not, what practice do you recommend?
    Thanks for answers! Cheers
    Tim Simmons replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
