Activity Forums Adobe InDesign Rotate Workspace? How in the Cow?
  • Rotate Workspace? How in the Cow?
    Posted by Toddytommy on September 4, 2006 at 8:47 pm
    So I got these handy calendar templates for a calendar I am making but when I go to edit the layout the calendar is placed on its side. It still prints fine and the Height X Width are still oriented as if it was facing right side up, its just annoying me to death and I am considering physically turning my monitor 🙂 I am sure it is simple to rotate but I just don’t know how… Any help would be greatly appriciated!
    Thank You!
    Kelly Johnson replied 20 years ago 2 Members · 3 Replies
  • Kelly Johnson
    September 4, 2006 at 10:28 pm
    We had new monitors that allowed us to rotate the view and adjusted the mouse accordingly.
    But, though a novel idea, it was really a novelty!
    Unless I’m missing something, you’re going to have to changed the size of the Document Layout and then rotate content.
    I would Select All, Group, change Document Layout the select the content and rotate it 90/-90 depending on how it’s oriented.
    That will have the 90 degrees remembered, but then you just print on landscape.
  • Toddytommy
    September 5, 2006 at 12:05 am
    I guess the part that confuses me is that the Width and Height for objects in the layout are correct as if it was rotated on its side.
  • Kelly Johnson
    September 5, 2006 at 3:45 am
    hmm… well if you could zip and email just the InDesign file, maybe I could see something different.
    Perhaps the objects were rotated initially in the layout and the output was saved as portrait?
    You can use kelly@thumbslinger.com if you want to send a page of the document.
