Activity › Forums › Adobe After Effects › Rotate word per character
  • John Cuevas
    January 14, 2014 at 8:08 pm
    If you don’t need the extra overshoot at the end of the rotation you can accomplish that quickly by using text animators. Create your text, open it up and under “Animate” select “Enable per character 3D”. Twirl open the animator and under “Add” choose scale. Twirl open the Range Selector & Advance and choose “Subtract”. Set the X and Z rotation to -45 and the scale to 0. Now set keyframes from 0 to 100 for the “End” property of the range selector.
    Here’s an example file: 6991_textrotation.aep.zip
    To learn more about Text Animators, check out these tutorials: After Effects basics tutorials by Andrew Devis, down towards the bottom.
    For more complex animations that can include Over shoot, check out Amortype 2.0
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
