Activity › Forums › Adobe After Effects Expressions › Rotate with an inertial bounce? Also scale?
  • Rotate with an inertial bounce? Also scale?
    Posted by Jim Dodson on October 12, 2012 at 4:10 am
    My new favorite expression (new to me at least) gives a nice inertial bounce on position values.
    Here it is (with Dan’s fix for divide by zero error):
    amp = .03;
    freq = 3.0;
    decay = 9.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){ t = 0;
    }else{
    t = time – key(n).time;
    if (n > 0 && t < 1){
    v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{value}
    My question is: Is there a similar inertial bounce expression for Rotation? ALSO
    For scale?
    Thanks guys!!
    Jim Dodson
    8 Core Intel — Mac – OSX
    Jim Dodson replied 13 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 12, 2012 at 5:07 am
    Did you try it with scale and rotation? It should be property agnostic.
    Dan
  • Jim Dodson
    October 12, 2012 at 2:36 pm
    ** Success**
    Turns out it works for scale (the amplitude was subtle so had to be increased to be noticeable). But, I got this error on orientation:
    “Velocity is not supported for the orientation property.”
    So it had to be used on “Rotation” where it worked PERFECTLY. (I really did test this before I posted Dan, I just didn’t see the bounce in the smaller icons because they were subtle — increasing amplitude helped.)
    As always Dan, thank you for your amazing talents!!
    Jim Dodson
