Activity Forums Apple Final Cut Pro Legacy Rotate Text Around Axis
  • Rotate Text Around Axis
    Posted by Ravi Kanda on March 3, 2011 at 3:46 pm
    Hi Guys
    This question has probably been asked before, so apologies in advance. I just cannot find the answer to this anywhere.
    I’m looking to rotate a mov file around a fixed axis.
    I can rotate it in FCP but the mov file rotates around the whole canvass.
    It’s similar to this effect.
    https://www.youtube.com/watch?v=7GJ3dCE2wIA
    It comes in at 12 seconds. The text rotates around it’s axis.
    Please help guys
    Chris Borjis replied 15 years, 6 months ago 4 Members · 5 Replies
  • Andrew Kimery
    March 3, 2011 at 9:21 pm
    In the Motion Tab adjust the Anchor Point and that will change the axis the image rotates on.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Ravi Kanda
    March 3, 2011 at 11:07 pm
    Hey Andrew
    I got my head around anchor points.
    What should the settings be if I want it to rotate around 1 axis?
    I have 2 fields.
  • Ravi Kanda
    March 3, 2011 at 11:31 pm
    Sorry I meant I CANT get my head around anchor points.
  • Andy Mees
    March 4, 2011 at 3:06 am
    Ravi
    You can grab my Better 3D plugin here : https://web.me.com/andymees (its way down at the bottom of the page) … add that to your Plugins folder (at /Library/Application Support/Final Cut Pro System Support/Plugins) and then quit ad restart FCP. You should then see it in the Effects > Video Filters > Perspective bin … add that to your text and then go to the Filters tab. You can spin it around the Z axis using the “Z axis Rotation” control, and you can change the anchor point for that spin by using the Anchor control … just click the “+” and then click (or click and drag) in the Canvas window to move the crosshair where you want the anchor point to be.
    Hope it helps
    Andy
  • Chris Borjis
    March 4, 2011 at 5:21 pm
    [Andy Mees] “You can spin it around the Z axis using the “Z axis Rotation” control”
    excellent!
