Activity › Forums › Apple Final Cut Pro Legacy › Rotate in FCP is not clean- any fix?
  • Rotate in FCP is not clean- any fix?
    Posted by Justin Ferar on September 19, 2005 at 5:47 am
    I’m rotating a shot 2 degrees because the tripod was not level for an establishing shot.
    The sequence is DV. Even when fully rendered the shot is blurry and shows strong artifacting. I have tried switching the “motion render settings” to “best” but have no luck getting a clean shot.
    I just thought that FCP 5.x would do a better job.
    Is there a work around within FCP?
    BTW I am using a pro monitor for my viewing pleasure.
    David Chai replied 21 years ago 4 Members · 5 Replies
  • Bob Delano
    September 19, 2005 at 5:33 pm
    Same problem here… used a high res photo file, cropped it, and rotated it 4 degrees… the result is pretty ugly. I tried deinterlace and a couple of other filters….no luck. I’d welcome any advice….
    Editor Bob
    Charlotte, NC
  • Justin Ferar
    September 19, 2005 at 6:21 pm
    I guess there is no fix.
    Luckily I have After Effects but what a PITA!
  • Kevin Monahan
    September 19, 2005 at 10:00 pm
    You guys have
    the dark green FULL bar checked in your Sequence>Render menus?
    Are you in Safe RT?
    High Quality (not Dynamic)?
    Full Frame Rate (not Dynamic)?
    Sequence + Settings> Video Processing Tab>Motion Filtering Quality>Fastest or Best seems to be better than Normal.
    Try these things. I have a pretty decent rotate right here in the Canvas at 100% with “Show as Sq. Pixels” unchecked.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Justin Ferar
    September 20, 2005 at 6:59 am
    I put the settings as you suggested and there is no difference.
    Oddly- even after effects shows slight blurriness- but is cleaner than FCP.
    Hmm.
  • David Chai
    September 24, 2005 at 3:09 pm
    IF you have motion use that, extremely clean rotation, just make sure anti alias is on in the project settings.
