Activity › Forums › Adobe After Effects › Rotate image around the anchor point
  • Rotate image around the anchor point
    Posted by Vishesh Arora on September 8, 2012 at 7:02 pm
    In the video below, I have Parented the position of leaf(center one) with the Brush position of CC glue gun effect using Pick-Whip.
    https://www.youtube.com/watch?v=0u8xYGoiFJ8
    Now whenever I pick-whip the position of leaf to that of brush, the leaf will be just above the correct position of brush. Now to bring it to the correct position I have moved the anchor point a little bit.
    Now the problem comes when I try to rotate the leaf. I want it to give some rotation with time like other leafs have but because of the anchor point which is not at the center of leaf, it will loose its original position with time.
    How cam I achieve this?
    Vishesh Arora
    VFX and Motion Graphics Artist
    https://digieffects.wordpress.com
    Vishesh Arora replied 14 years ago 2 Members · 2 Replies
  • Darby Edelen
    September 9, 2012 at 8:27 pm
    Can’t really tell what’s happening in the video. However, from your description I’d recommend tying the Glue Gun point to a null object instead of directly to the leaf. Use the null to drive the Glue Gun position. Parent the leaf to the null object and rotate it separately around its own axis.
    Darby Edelen
  • Vishesh Arora
    September 10, 2012 at 12:09 pm
    Thanks Mr. Edelen.
    It works perfectly fine when I am using a null object and parenting the leaf to it.
    Thanks a lot 🙂
    Vishesh Arora
