Activity › Forums › Adobe After Effects › Rotate each word using text animator
  • Rotate each word using text animator
    Posted by Kate Koyama on December 21, 2009 at 3:43 pm
    Hello!
    I’m trying to animate each word on a sentence in after effects. I want each word to rotate -90 degrees at different times (one slightly after the other). I applied animate>rotation. Then I set the rotation from 0 to -90, and the offset value from -100 to 100. But All the words still rotate together.
    Can anyone help me with this, please??
    John Cuevas replied 16 years, 9 months ago 2 Members · 1 Reply
  • John Cuevas
    December 21, 2009 at 4:43 pm
    Couple things you need to check quickly. First, when you twirl down “text” open up “More options” and change the anchor point grouping to “word”. In your animator change the “Based On” to “word” also.
    You should be able to do this just adding keyframes to the “end” value. I just tried it quickly and it worked fine.
    Johnny Cuevas, Editor
    http://www.ckandco.net
