Activity Forums Apple Final Cut Pro Rolling Edit Tool?
  • Rolling Edit Tool?
    Posted by Alex Hawkins on September 3, 2012 at 6:43 am
    OK so is it just me or can you not perform a rolling edit on a secondary storyline?
    Alex Hawkins
    Canberra, Australia
    Alex Hawkins replied 14 years ago 3 Members · 3 Replies
  • Alex Gollner
    September 3, 2012 at 5:04 pm
    If you have two adjacent clips with a connection location each, you can’t use the roll tool. You need to select the clips and make them into a secondary storyline using the Create Storyline command.
    ___________________________________________________
    Alexandre Gollner,
    Editor, Zone 2-North West, London
    alex4d on twitter, facebook, .wordpress.com & .com
  • Andy Neil
    September 3, 2012 at 5:57 pm
    If you’re using the trim tool, you should be able to perform a roll edit on clips in a secondary storyline. This doesn’t work if the clips are merely connected clips, so maybe that’s your problem?
    Andy
    https://www.timesavertutorials.com
  • Alex Hawkins
    September 4, 2012 at 12:51 am
    Gotcha. Thanks heaps guys.
    Cheers.
    Alex Hawkins
    Canberra, Australia
