Activity Forums Blackmagic Design Rolling Desktop – Decklink HD Extreme Pro
  • Rolling Desktop – Decklink HD Extreme Pro
    Posted by Edward J destructo on October 10, 2006 at 9:39 pm
    Anyone else had a problem with a rolling dektop display on PC. We are running the latest everything and have rock solid output from AE etc but get a rolling display from outside any of the supported programs via SDI.
    Any ideas?
    Luke Maslen replied 19 years, 10 months ago 2 Members · 3 Replies
  • Luke Maslen
    October 11, 2006 at 5:45 am
    Hi Edward,
    Is it only the display of your desktop that rolls? If so, the solution is probably to set your desktop to the same format as the video that you use in applications such as Premiere Pro or After Effects. Please see Page 11 of the DeckLink Manual which is included as a PDF file in the latest drivers. Does that help?
    If not, please provide a few details of the video format you are working with, the make and model of your monitor and also whether you are using genlock or trisync and to which video format it is set.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Edward J destructo
    October 11, 2006 at 8:33 am
    Thanks Luke. That fixed my problem in about 15 seconds. You are a champ. A tireless champ 😉 There is a lot to learn about these new cards for me. Your help through these forums is very much appreciated. Keep up the good work.
    Cheers
  • Luke Maslen
    October 12, 2006 at 12:28 am
    Hi Edward,
    Thank you for your kind words and good news. I’m happy that solved the problem.
    Regards,
    Luke Maslen
    Blackmagic Design
