Activity Forums Adobe After Effects Rolling Cube
  • Rolling Cube
    Posted by Jiri Fiala on May 22, 2007 at 7:58 pm
    Hello, I need to do a comp with rolling cube (dice). Now how do I go about this to make it look real? I tried moving anchor points and then rotating, but there has to be a simpler way. My results looked unusable. Please help, thanks.
    Steve Roberts replied 19 years, 3 months ago 2 Members · 1 Reply
  • Steve Roberts
    May 22, 2007 at 8:53 pm
    If you create a null object, then arrange six squares so they surround the null (the null is in the center), then parent the squares to the null, you will be able to move, rotate the null and have the squares follow.
