Activity › Forums › Adobe Premiere Pro › Roll edit tool question
  • Roll edit tool question
    Posted by Gabriel Regalbuto on August 20, 2012 at 4:16 pm
    When using the roll tool in CS6 I seem to be constrained by the adjacent clip. I would like the ability to roll over multiple edits if I want, but Premiere blocks me, preserving the last frame of the adjacent clip. Is there a way to override this?
    Angelo Lorenzo replied 14 years, 1 month ago 2 Members · 1 Reply
  • Angelo Lorenzo
    August 23, 2012 at 7:37 pm
    I don’t believe so, the clip will need to be deleted before you can continue to roll over the clips.
    The rolling edit tool affects clips on both sides of the edit so it treats each as blocks you want to keep, rather than one block overwriting the other.
    Maybe a suggestion to Adobe to add an overwrite edit tool, but for now no dice.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
