Roger Bansemer: Solution for Particle Ilusion
Posted by Graham Bernard on August 11, 2020 at 5:03 amRoger, as that other thread was wandering away from the initial Postee, I thought it polite and respectful to start a NEW Thread for your question concerning pI and its ALPHA.
Do not use the Render setup you used. I reproed your results using your settings and that does NOT give you ALPHA.
I used the QT setting that was offered by Particle Illusion and got success:
What are your thoughts? What is your feedback?
* Grazie
PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
Cameras: Canon XF300 + PowerShot SX60HS BridgeRoger Bansemer replied 6 years, 1 month ago 4 Members · 30 Replies -
Roger Bansemer
August 11, 2020 at 7:33 pmLooks good. Don’t get upset with me but what settings exactly did you use to give you that transparent checkerboard in your PI render because I think I’ve tried them all with no success.
Was it in the render that you achieved that or in a preference set up in PI?Roger Bansemer – PaintingAndTravel.com
Graham Bernard
August 11, 2020 at 9:04 pm[Roger Bansemer] “Looks good.”
Thank you Roger.
[Roger Bansemer] “Don’t get upset with me”
I invited you 4 times to read this thread. I even downloaded pI so I could assist you too. Be thankful I’m persistent with you! – Moving on . . .
[Roger Bansemer] “Was it in the render that you achieved that or in a preference set up in PI?”
This is NOT an either/or scenario – it’s both.
A] Set PI Prefs to match what I’d be going to in VP. Here’s for those Falling Leaves:
B] Here’s the pI render settings I just used for those Leaves:
C] VP Settings to have Floating Point 32 bit:
10pm here in London . . . ZZZZzzzzzzz. . . . . .
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Roger Bansemer
August 14, 2020 at 12:34 pmHi Graham,
I appreciate the posts. I really do. However even when I use the settings you showed exactly I don’t get the transparency. I think what the person from Boris told me in an email that in order to have it show up that way it has to be purchased.Roger Bansemer – PaintingAndTravel.com
Graham Bernard
August 14, 2020 at 1:42 pm[Roger Bansemer] “I think what the person from Boris told me in an email that in order to have it show up that way it has to be purchased.”
You think, so you aren’t sure? In any event, not being able to demonstrate the value of Pi in a NLE would be crazy! I used the Freebie and got ALPHA. Do a MediaInfo on your Rendered “ALPHA” media and let’s see.
I have contacts at BORIS and I can follow through.
* Grazie
Roger Bansemer
August 14, 2020 at 5:14 pm -
Graham Bernard
August 14, 2020 at 5:25 pmRoger, are you saying that the Media has no ALPHA because you’re seeing “None” in that field?
* Grazie
Roger Bansemer
August 14, 2020 at 5:34 pmCorrect. It’s been listed at NONE no matter what setting I have render in with PI.
I’ve also changed that field from None to Alpha and nothing happens.
RogerRoger Bansemer – PaintingAndTravel.com
Graham Bernard
August 14, 2020 at 5:39 pm[Roger Bansemer] “Correct. It’s been listed at NONE no matter what setting I have render in with PI.”
Oh I’m so glad I’ve persisted with you – dear heart . . You see that TINY Down Arrow, click on it. I see options for ALPHA – what are you seeing . . . tick . . tock . . tock . .
* Grazie
Graham Bernard
August 14, 2020 at 5:43 pm[Roger Bansemer] “I’ve also changed that field from None to Alpha and nothing happens.”
Did you then Click APPLY?
* Grazie
Graham Bernard
August 14, 2020 at 5:45 pmCorrection – Click on OK.
* Grazie
