Activity Forums Audio Rode NTG-2 Issue
  • Rode NTG-2 Issue
    Posted by David C jones on September 16, 2014 at 7:53 pm
    Greetings,
    I seem to be having a problem with the Rode NTG-2 mic. It sounds good when phantom powered, but when I use the internal AA battery I get a nasty, static sound (in addition to the audio). I’ve tested two of these mics with different recorders, inputs, cables, batteries. They both have the same issue. Am I missing something or do I just have two bad, brand new mics?
    DCJ
    Clyde Villegas replied 11 years, 11 months ago 3 Members · 5 Replies
  • Bob Kessler
    September 17, 2014 at 12:12 am
    Are you sure that the external phantom power is OFF when using the internal phantom power?
    Peace,
    Bob
    ____________________________________________________________________
    Filmmaking is the art of the invisible;
    If anyone notices your work you haven’t done your job right.
  • David C jones
    September 17, 2014 at 4:04 am
    After further testing, it seems that if I switch from phantom power to mic (turning phantom power off) I get that noise. However, it does fade away after about 2 minutes. As long as I don’t switch back and forth between the two it’s fine.
    DCJ
  • Clyde Villegas
    September 19, 2014 at 11:03 pm
    Hi David. Just curious, what audio recorder are you using with the NTG-2? Thanks!
    ut in omnibus glorificetur Deus
  • David C jones
    September 20, 2014 at 1:53 am
    I’m using the Sound Devices 633. However, I got the mic to use as an on-camera mic with the Blackmagic 4K camera.
    DCJ
  • Clyde Villegas
    September 20, 2014 at 2:18 am
    Thanks for the info, David.
