Activity › Forums › Adobe After Effects › Robotic arm replacement
  • Robotic arm replacement
    Posted by Travis Heberling on October 19, 2010 at 10:21 pm
    So i am working on this shot for one of my classes….basically a guy is going to walk into a room while HUD’s are circling around him, the camera will then work its way to an over the shoulder shot of a hud that has information about a robotic looking arm. The guy will confirm some things and we will cut to a shot of the arm which will be transforming into a robotic arm. I was curious on what would be some good options to go about this. I was thinking of creating a 3d arm and masking it on, In a pixel by pixel kind of style, another idea would be to actually create a more holographic looking arm covering up his original arm.
    here is a rough edit of what the shots will look like.
    https://www.youtube.com/watch?v=xqFMK7uLdn0
    Thank you!
    Travis Heberling replied 15 years, 11 months ago 2 Members · 2 Replies
  • Walter Soyka
    October 20, 2010 at 12:44 am
    [travis heberling] “The guy will confirm some things and we will cut to a shot of the arm which will be transforming into a robotic arm. I was curious on what would be some good options to go about this. I was thinking of creating a 3d arm and masking it on, In a pixel by pixel kind of style, another idea would be to actually create a more holographic looking arm covering up his original arm.”
    You’ve got lots of options — I think it would all depend on how you want the robotic arm to look. Do you have a design for the arm?
    You could explore either of the options you described, you might build the arm on Transformers-style, you could create a device that scans over the arm and builds it over the arm, you could wipe the robot arm on under a flare.
    Walter Soyka
  • Travis Heberling
    October 20, 2010 at 3:38 am
    I have a doodle of it…Ill have to to scan it in.
    Its nothing to complex just kind of picture a standard arm just metallic and tech like effects applied to it.
