Activity › Forums › Apple Final Cut Pro › Ripple delete stacked clips
Posted by Oliver Peters on February 2, 2012 at 1:53 amOK, brain fade or I’m missing something. I have 4 stacked clips (primary + 3 connected). I want to do a ripple delete across all clips – video + audio. Old way would be mark in/out, ripple delete. What’s the new way? Right now I’m not finding it and neither the magnetic timeline nor position mode is helping the situation. TIA.
– Oliver
Jeremy Garchow replied 14 years, 7 months ago 3 Members · 14 Replies -
Jeremy Garchow
February 2, 2012 at 1:58 amSelect primary and hit delete.
Unless I’m missing what you’re trying to do.
Oliver Peters
February 2, 2012 at 2:01 am[Jeremy Garchow] “Select primary and hit delete.”
That only deletes that portion of the primary. Not across all clips.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Jeremy Garchow
February 2, 2012 at 2:10 amThat’s not what you want to do? Sorry I’m cornfused. Long day.
You don’t want to ripple the length of the deleted primary clip?
Oliver Peters
February 2, 2012 at 2:11 am[Jeremy Garchow] “You don’t want to ripple the length of the deleted primary clip?”
Think of a quad split. 4 stacked clips of equal duration. I want to simply take 1 sec. out of the middle. (No, I don’t want to use compound clips.) This is a piece of cake in any NLE.
– Oliver
Orlando, FL
Jeremy Garchow
February 2, 2012 at 2:21 amGot it.
Skim to in point, command b, skim to out point, command b, delete middle primary.
Or compound, range, delete, break apart.
Oliver Peters
February 2, 2012 at 2:24 am[Jeremy Garchow] “Skim to in point, command b, skim to out point, command b, delete middle primary. “
Nope. Doesn’t work. It’s only extracting the middle of the primary, not all 4 clips.
– Oliver
Orlando, FL
Oliver Peters
February 2, 2012 at 2:32 am[Jeremy Garchow] “Lasso stack and delete”
What’s the command to “Blade” across all clips at once. That would be needed to do this.
– oliver
Orlando, FL
Jeremy Garchow
February 2, 2012 at 2:35 amCommand-b isn’t blading all? Is the stack dejected when you blade?
Oliver Peters
February 2, 2012 at 2:38 am[Jeremy Garchow] “Command-b isn’t blading all? Is the stack dejected when you blade?”
No. Only the primary. What do you mean “dejected”?
– Oliver
Orlando, FL
