Activity › Forums › DaVinci Resolve › Ripple Delete keyboard shortcut not working on Windows machine
  • Ripple Delete keyboard shortcut not working on Windows machine
    Posted by Kenneth Maultsby on December 2, 2018 at 12:50 am
    Just discover this problem while taking a training course. My Ripple Delete shortcut is not working. I did a mark in and a mark out on a section in the timeline and attempted to do a Ripple Delete which the command should be Shift + Backspace. It will work if I go to the Edit drop down and select Ripple Delete. I also checked the Keyboard Customization and it is ok. I also did a test on the Edit drop-down list and did a Ripple cut which is Ctrl Shift X which shortcut did work which is the same thing. At least it worked the same way. Any suggestions?
    Glenn Sakatch replied 7 years, 10 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    December 2, 2018 at 4:17 pm
    on my box it is just the delete key as opposed to the backspace key which is a non ripple delete.
    Glenn
