Activity › Forums › Adobe After Effects › Ring Warp effect
  • Ring Warp effect
    Posted by Nick Hill on September 22, 2009 at 12:56 pm
    Hi
    Is there such a thing as a Ring Warp effect anywhere? Imagine you have a cartoon sun and you want the rays to sort of wiggle back and forth in a sinewave. I know you can get close by doing polar to rect coords, then wave warp, then rect to polar again, but all that polaring makes the results very pixelly. Ideal controls would be something like
    inner & outer radius
    type (sinewave, triangle etc)
    period, phase
    tapering (to blend it in with the rest of the layer)
    wave height, length etc
    anyone seen anything like this?
    Mike Park replied 17 years ago 2 Members · 1 Reply
  • Mike Park
    September 22, 2009 at 3:05 pm
    Why not use a displacement map made from a layer, circle effect and animated turbulent noise layer. It will get you pretty close. Just mask out what you don’t want effected.
