Activity Forums Maxon Cinema 4D Rig problem
  • Kouraib Abdmalek
    June 10, 2026 at 10:21 am
    Hi Hans,
    I think the problem might not be clear before checking the file, but it is assumed that the preset is not related to the problem because, as its name suggests, it is attached to clothing, so the problem is in the riging movement before applying the preset to the body.
  • Hans Loosman
    June 11, 2026 at 2:09 pm
    Hi Kouraib
    Thanks for you reply, here is the file.
    Would be great if you can give me a hint.
    Regards
  • Kouraib Abdmalek
    June 13, 2026 at 8:43 am
    Hello Hans,
    Thank you for sharing the file with us! I’ve reviewed it, but I haven’t been able to pinpoint the source of the problem, especially with so many components and Expresso tags. I don’t know if this issue was already present in the Preset Animation file or if it appeared after some modifications were made.
