Activity Forums Adobe After Effects RGB vs YUV
  • RGB vs YUV
    Posted by Hallie Mullins on August 16, 2011 at 6:42 pm
    We are shooting a promo reel using a green cyc and a white cyc. The environment for our reel is white and we have 3D elements. We are shooting on a Vericam 3700 to a cinedeck via dual link SDI. We will be recording to 10 bit uncompressed or Pro Res 4444. What is your opinion on using RGB vs YUV when working in AE? Thanks!
    Ben G unguren replied 15 years, 1 month ago 2 Members · 1 Reply
  • Ben G unguren
    August 16, 2011 at 7:44 pm
    AE works in RGB, not YUV, so if you start with RGB then that’s one less conversion the program has to make. Though if you’re shooting YUV 444 I don’t think it will make a huge difference (RGB is inherently 444, as it were).
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
