Activity Forums Adobe After Effects RGB to XYZ color space conversion
  • RGB to XYZ color space conversion
    Posted by Ron Kozub on June 29, 2007 at 3:15 pm
    I’m presently working on a digital cinema unit which compresses scanned tif files to the DCI compliant jpeg 2000 format for projection in theatres. The files are in the RGB color space and need to be converted
    to the XYZ color space prior to compression. Does anyone know of any
    available hardware or software that would do this.
    Ron
    Jan Vork replied 12 years, 10 months ago 6 Members · 5 Replies
  • Sam Moulton
    June 29, 2007 at 3:39 pm
    do you mean yuv?
  • Steve Roberts
    June 29, 2007 at 3:56 pm
    Yow. New stuff to me. The best I could suggest would be to Google “RGB to XYZ” (I’ve seen some transformational matrices there) or go to the Expressions COW.
    Sorry …
  • Brendan Coots
    June 29, 2007 at 8:37 pm
    https://rsb.info.nih.gov/ij/
    This does it, although I make no claim to how easy it is to use, workflow etc.
    If you look in the plugins portion of the link there is an RGB to XYZ coversion plugin as part of this app.
  • Adolfo Rozenfeld
    June 30, 2007 at 12:29 am
    This is included in the color management functionality in AE CS3.
    There will be a terrific PDF document explaining the correct settings for different workflows, including this one.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    ar(AT)adolforozenfeld.com
  • Jan Vork
    October 30, 2013 at 3:14 pm
    And where is this terrific .pdf? 🙂
    http://www.jaydude.nl
