Activity Forums Adobe After Effects RGB reassembly
  • RGB reassembly
    Posted by Jon Weigand on September 1, 2005 at 10:23 pm
    Howdy CC’ers
    I’ve been trying to take a red layer, a green layer, and a blue layer and reassemble them into one image, using those three layers as RGB components. My first thought was to use ‘Set Channels’, but the result doesn’t look like it should. It’s possible that my layers are not right for creating the image that I’m expecting, but how about that RGB assembly process? Has anyone done the same? Am I on the right path?
    oh, for more detail – I have a comp with three layers in it, each representing a channel from R, G, & B. Then I add a Solid to the comp and apply ‘Set Channels’, using the red channel from the red layer, and so forth.
    thanks in advance,
    JohnnyW
    Bill Clotz replied 21 years ago 2 Members · 1 Reply
  • Bill Clotz
    September 2, 2005 at 12:38 pm
    I think you might need to convert your layers to grayscale first.
