Activity › Forums › VEGAS Pro › RGB – preview on PC monitor
  • John Rofrano
    May 5, 2009 at 10:45 am
    > Should I use “Video output FX – Color corrector – Studio RGB to computer” in the preview window while editing, and than unhook before rendering to DVD Architect template?
    Yes, if you are color correcting to the preview window. If you are using the Windows Secondary Display, you can toggle Computer RGB on in those settings so no need to add the FX. Also if you use an external monitor via firewire there is no need for this. It’s only needed when color correcting via the preview window and then it can be removed before rendering.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
