Activity Forums VEGAS Pro RGB or sRGB for producing photo slideshow in MPEG-2 for DVD
  • RGB or sRGB for producing photo slideshow in MPEG-2 for DVD
    Posted by Steven Broido on March 3, 2010 at 4:37 pm
    Hi All,
    Been searching the forums for an answer to this and have seen some conflicting information.
    Here’s what I’m trying to do:
    – Produce a 60 minute ‘slideshow’ video of photographs that pan, zoom, and fade in and out of each other.
    – Produce this in MPEG-2 format so it can be played on a standard DVD player.
    Should I be producing the photgraphs in RGB or sRGB format from photoshop for import into Vegas?
    Also, since this DVD isn’t intended for broadcast, do I have to worry about broadcast safe colors?
    If so, do I just run the SONY BROADCAST COLORS effect once complete and call it a day?
    I mostly produce video for the web so this is new territory for me…
    Any help is greatly appreciated!
    Steve
    Steven Broido replied 16 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    March 3, 2010 at 6:00 pm
    As long as you are processing them in Photoshop, you want your images to use sRGB and Photoshop has a broadcast safe action as well. If you use the Sony Broadcast Colors it will simply clamp down the black and white points which could loss detail in certain photos. I believe doing it in Photoshop will adjust the levels to be within the broadcast safe range so that you don’t loose any detail.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steven Broido
    March 3, 2010 at 6:57 pm
    Thanks Jon!
    I really appreciate the quick response!
    S
