Activity Forums Adobe After Effects RG Horizon in AE with camera rig problems
  • RG Horizon in AE with camera rig problems
    Posted by Jimmy Brunger on January 18, 2011 at 12:40 pm
    Hi all,
    I posted this in Trapcode forum, but don’t know how frequented that is, so just thought I’d try here as a bit urgent. Hope someone can help!….
    I’ve setup an AE project using a standard simple camera rig for extra control – using a series of parented nulls with sliders to control each cam move – one for bank, one for pitch, heading, tracking etc. I’ve then split X,Y & Z pos on the main controls null for cam tracking.
    This works great for all my 3D layers and for Particular, but Horizon doesn’t seem to be reacting to the tracking and 3 x position controls. All my other 3D layers move as expected, but only the X, Y & Z *rotation* controls are doing anything for Horizon.
    Any ideas if this is right or if I can adapt my rig to gain full control of my Horizon BG?
    Jim.
    Jimmy Brunger replied 15 years, 7 months ago 2 Members · 4 Replies
  • Michael Szalapski
    January 18, 2011 at 2:57 pm
    Horizon’s normal behavior is to move for rotation, but not for position changes. It won’t get smaller when the camera moves back in z space, nor will it move to the side when the camera moves on x. Perhaps I misunderstood your problem. Does it do something different when you have a camera in your comp that isn’t set up with that rig?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jimmy Brunger
    January 18, 2011 at 4:16 pm
    Hi Michael,
    Thanks for your reply. It definitely behaves differently when I move the camera via the null rig, as opposed to the camera itself. Didn’t realize Z-pos had no affect on the Horizon layer (perhaps it should partially?) but my problem is if I want to track the camera left or right, or up/down the horizon BG doesn’t move at all, whereas my particular stars, etc do move with the camera..
    Quick fix at the moment is to make sure I tilt the camera as I track, ever so slightly – which gets the BG moving a touch and looks more realistic, but not ideal.
  • Michael Szalapski
    January 18, 2011 at 8:31 pm
    Horizon is meant to be an image at infinite distance, whereas Particular is giving you particles at a set place in 3d space. Therefore Horizon won’t move in Z space since it’s an infinite distance (but of course Particular’s particles do since your camera is getting closer to them). If you want your stars to move with your sky (and I suspect you would), I would suggest putting your stars in whatever precomp you’re using for your Horizon map.
    As for why it’s moving differently in your rig, I’m not sure why that is; probably a limitation of the plugin.
    Here are my thoughts on why that is. (Take them with a bit of salt as my computer is in the middle of a render and I can’t test this and I haven’t used Horizon enough to have this problem.)
    It’s possible that Horizon looks at the camera’s position data, but if the camera is parented to another layer it’s position data does not change. Perhaps if you used a parented null object and put an expression on the camera’s position to follow the null’s actual world position it would do the trick.
    L=thisComp.layer("NULL_OBJECT");
    L.toWorld(L.anchorPoint):
    or something similar…
    – The Great Szalam
  • Jimmy Brunger
    January 19, 2011 at 4:05 pm
    Thanks Michael, will try that.
