Activity › Forums › Adobe After Effects › RE:Visions Fields Kit and eyeon Fusion 5.2/5.3
  • RE:Visions Fields Kit and eyeon Fusion 5.2/5.3
    Posted by Mark Dauth on January 13, 2010 at 9:58 am
    I am trying to run RE:Visons FieldsKit in Eyeon Fusion 5.2 and 5.3 32bit.
    The Aex files are Read corectly and the Plugin is avalible in the AE Plugin list but when i connect a loader with fieldet footage (set to fullframes) to it the immage turnes bright magenta and i do not see the result of the defield. the settings sliders are all avalible.
    i am running a 32bit version of Fusion on a Vista x64 System.
    everything else is pretty standard.
    RE:Visions Real Smart Mation Blur works fine.
    does anybody have any ideas?
    Ciao Mark
    Pierre Jasmin replied 16 years, 8 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    January 13, 2010 at 4:46 pm
    You have to connect the second input of node for it to work.
    We had to do that historically as some cases otherwise did not work properly in Fusion.
    Pierre
