Activity Forums Adobe After Effects Re:Vision Morph – overlap and smearing
  • Re:Vision Morph – overlap and smearing
    Posted by Ryan Daily on October 3, 2008 at 7:01 pm
    I am correcting some footage that has digital artifacts in it by taking the first good frame and the last good frame and morphing between the two.
    My problem occurs when the subject’s legs cross one in front of the other. Has anyone experienced this and more importantly does anyone know how to work around this scenario?
    Thanks for your help.
    Windows x64
    After Effects CS3
    Re:Flex Morph 3.1.4
    Pierre Jasmin replied 17 years, 11 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    October 3, 2008 at 11:12 pm
    Seems like you have a problem similar in thread below
    Since you only have two frames and as per your description a lot of areas of the image is not visible on the other frame, you might need to break the process in two, removing all the subject minus the back leg on a back layer and completing the “limb” invisible on a frame with a paint system – morph that as the under layer, then do a foreground layer morph (a second morph) with the subject without a back leg. Of course all the TO layer prework will need to be done in a precomp.
    Pierre
