Activity › Forums › Adobe After Effects Expressions › Reversing the comp’s Y coordinates
  • Reversing the comp’s Y coordinates
    Posted by S. Marcotte on July 11, 2008 at 4:31 pm
    I’m looking to move the Y zero coordinate from the top of the frame to the bottom, so it will match some tracking data from PFTrack. If there is a solution, please tell me where to type the expression as well. I’ve never had to use one before.
    Thank you.
    S. Marcotte replied 18 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    July 11, 2008 at 4:48 pm
    I think you would apply an expression like this to the position property:
    [value[0],thisComp.height – value[1]]
    That should move y = 0 to the bottom, and +y will be up. Is that what you were after?
    Dan
  • S. Marcotte
    July 11, 2008 at 5:07 pm
    That sounds like what I’m looking for. But I should have mentioned, I’ve never applied an expression before. How is it done?
  • Dan Ebberts
    July 11, 2008 at 5:12 pm
    Just alt click the position stopwatch and paste in the expression text.
    Dan
  • S. Marcotte
    July 11, 2008 at 5:15 pm
    Yes. Good. It seems to work. Thanks for that.
    Serge
