Activity › Forums › Adobe After Effects › Reversing path direction
  • Reversing path direction
    Posted by Tzi2k4 on September 14, 2007 at 10:02 am
    Hi!
    After being able to set my first vertex of a path, the path is now reversed?
    I drawed it clockwise: starting on the map of Ireland in Dublin going south, then west, up to the north and to the east again.
    After I have choosen the first vertex to be in Dublin, I ended up with the path counterclockwise? I goes now first to the north-west, then south, then east and then north again.
    Any idea how to fix this? One note: I have a mask and I was unable to find the “reverse direction” button. Do I need to convert the mask to a path? (How?)
    TIA!
    Thomas
    Tzi2k4 replied 19 years ago 2 Members · 4 Replies
  • Steve Roberts
    September 14, 2007 at 12:34 pm
    Why do you want to reverse direction? If you’re using stroke, animate the start point instead of the end point.
  • Tzi2k4
    September 14, 2007 at 1:12 pm
    Hi!
    That did not change anything 🙁
    I tried animating the end of the stroke effect it goes counterclockwise and if I animate the start of the stroke effect it goes countclockwise too!
    Any ideas left?
    TIA!
    Thomas
  • Steve Roberts
    September 14, 2007 at 1:42 pm
    Leave the end at 100, and animate the start from 100 to 0, no?
  • Tzi2k4
    September 14, 2007 at 1:59 pm
    Hi!
    Thank you, it works now! Got a lesson learned 😉
    TIA, Thomas
