Activity Forums Apple Final Cut Pro Legacy reversing order of a string of photos w/transitions
  • reversing order of a string of photos w/transitions
    Posted by Craig Johnson on February 15, 2013 at 4:44 am
    Just like the topic line reads. I have a project with about 45 photos running consecutively with a basic transition between each, at the end of the video, I would like to flip the order with transitions intact. I’ve tried a few basic things but no joy. Is there such a feature?
    Rafael Amador replied 13 years, 7 months ago 3 Members · 2 Replies
  • Todd Gillespie
    February 15, 2013 at 6:46 am
    Either render a movie or nest a sequence. Then make a new sequence and reserve the timing. Only way i can think. But the movement will also be in reserve. May not be what you want.
    Todd at UCSB
    Television Production
  • Rafael Amador
    February 15, 2013 at 1:45 pm
    ..or you can use the free “Reverse” plugin, that basically does the same than what Todd suggested:
    https://www.nattress.com/Free/freeFCP.htm
    The truth is that Nattress developed this plugin because setting the speed at -100% has a bug in FC, but that’s with interlaced stuff, so no your case.
    rafael
