Activity Forums Adobe After Effects Expressions Reversing Levels adjustment with an expression
  • Reversing Levels adjustment with an expression
    Posted by Sean Lewis on October 4, 2017 at 1:21 pm
    Hi all,
    I am working in 32 bit linear and I have added a levels and exposure effects on a plate. Which is a temporary grade while I work. (Do not ask why, long story!)
    In Nuke this process is non-destructive so you can reverse the grade as a post process and not worry about pixel crunch/artifacts.
    In this instance though it is not working the same way.
    Below are the expressions for the following (in the same order)
    Exposure: Exposure
    Levels (Individual Controls:
    Input Black
    Input White
    Gamma
    And I’m linking these to the original effects.
    The exposure one works fine but the levels does not.
    If anyone could help that would be brilliant!
    Thanks in advance
    effect("Exposure")("Exposure")*-1
    effect("Levels (Individual Controls)")("Input Black")*-1
    1+(1-effect("Levels (Individual Controls)")("Input White"))
    1+(1-effect("Levels (Individual Controls)")("Gamma"))
    Sean Lewis replied 8 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
